Re: 9N will not crank
Posted by HCooke on May 11, 2026 at 18:00:16 [URL] [DELETE] :
In Reply to: 9N will not crank posted by KYDon on May 11, 2026 at 15:32:51:
Make 100% sure the tractor is in neutral. Use jumper wire and jump between a good ground and the starter lug on top of the starter motor. If the starter motor spins, the the problem is in the starter switch. If the starter does not spin, the problem is the starter motor.
