In Reply to: Re: 641 Hydraulics question posted by Ultradog MN on July 02, 2017 at 03:09:36:
If I was as concerned about hose clutter as you and willing to spend that kind of money I would opt for something truly state of the art. For a couple hundred less than the cost of a new OEM style two spool valve and couplers you can add three DA/SA selectable solenoid actuated spools with couplers and an electric joystick. No fuss, no muss - screw the joystick to your armrest where it would be on a modern machine and put the valve where you want the outlets. The only hose runs you will have are pressure and return between the HVxxxx manifold and the new valve. If you are handy they could be 1/2" hard lines and you could mount it right under the seat where the OEM style valve would go and minimize those runs. Of course it requires another modern innovation - 12V electrics ;-)
TOH
Posting not permitted in the forum archives.<1499007467">
