In Reply to: Rough running 51 N posted by Tom from Mi. on January 03, 2016 at 14:21:05:
Spark plug wires shorting out. #1 will reach TDC at both the compression stroke and the exhaust stroke. Difference being that at TDC of the exhaust strke, the rotor will be 180 degrees off when you pull the cap. Hence the 4 stroke engine. Intake, compression, power and exhaust.
Posting not permitted in the forum archives.<1451849798">
