Wobble on the Right Front
Posted by John (AL) on February 19, 2014 at 09:35:01 [URL] [DELETE] :
The right front wheel on my 51 8n wobbles horribly in 4th gear. The spindle is set correctly and keyed, so That can be eliminated. I've tightened the drag arm and adjusted the tension screws on the steering box. That helped some, but the wheel is still wobbling, so I assume the problem is inside the steering box, right?
Is there anything, short of a total rebuild of the steering box, that can be done to fix the problem?
Posting not permitted in the forum archives.<1392820501">
