Re: Wobble on the Right Front
Posted by Tim Daley(MI) on February 19, 2014 at 18:31:21 [URL] [DELETE] :
In Reply to: Re: Wobble on the Right Front posted by John (AL) on February 19, 2014 at 12:01:09:
Toe-in is explained in the Original 8N Operator's Manual. the front wheels should be turned slightly inwards, about 1/4" at the front from the back when the steering wheel is straight. You have to play with the drag links to get it right. As mentioned, there are marks to eyeball the settings. Early 8N's had the spindle tops cast with a boss to make it easy and later ones used chisel marks. You need to do all the other work first to ensure the parts are going to mesh. New spindle bushings, kingpin, drag front links, and lubed steering box. See How-To's for adding a grease nipple to use cornhead grease rather than oil. Bear in mind that one drag link is longer than the other so don't take them off and get mixed up.
Posting not permitted in the forum archives.<1392852681">
