Re: Governor Leaking Around Throttle Arms
Posted by Del Huebner on January 24, 2014 at 16:01:44 [URL] [DELETE] :
In Reply to: Re: Governor Leaking Around Throttle Arms posted by John (AL) on January 24, 2014 at 15:49:40:
You have to pretty much dis-assemble the governor to remove that seal. The pin in the governor fork has to be removed to get that lever assembly out. Since you are that far into it you may find you need more than just the seal. If it was me and the leak is not that bad and the governor still functions as it should I would just leave it as is.
Posting not permitted in the forum archives.<1390597304">
