In Reply to: Re: 9N only runs smooth with choke out posted by HCooke on April 21, 2013 at 17:22:03:
Thanks--
I did remove plug at bottom of carb, a small amount (less than a shot glass full) of fuel came out then stopped....this was with engine off and fuel valve on sediment bowl closed.....should I do this with valve open and/or engine running ? I will check spark. Probably a day or two until I can do more tests, got work and kids to deal with Monday morning. I'll post back after I try these things
Posting not permitted in the forum archives.<1366582431">
