Re: 9N only runs smooth with choke out
Posted by Allen and Beth on April 21, 2013 at 21:06:50 [URL] [DELETE] :
In Reply to: Re: 9N only runs smooth with choke out posted by Mark on April 21, 2013 at 19:25:04:
I read the other post about weak spark,which could also be correct,if that turns out to be the problem, or part of it,after you check points and cond.also check wires coming out of back of ign. switch. I had a problem one time with weak spark and found wires on back of ign. switch badly burned.God Bless Beth and Allen
Posting not permitted in the forum archives.<1366592810">
