Re: Clutch Question
Posted by JMOR on December 26, 2013 at 17:00:52 [URL] [DELETE] :
In Reply to: Re: Clutch Question posted by SteveVA on December 26, 2013 at 16:40:45:
Doesn't sound like it would do any good to block it down, as in absence of any spring push-back, it isn't even touching the pressure plate fingers. I would look to correct linkage assy & adjustment. Before splitting, I would disconnect linkage from the shaft passing through the belly & pipe wrench it CCW to see if I could get the spring push-back. If not, the throughout bearing could possibly be installed incorrectly or the release fork could be slipping on the shaft or slip might be at link to shaft near pedal linkage (exterior).
Posting not permitted in the forum archives.<1388095252">
