In Reply to: Re: Clutch Question posted by Don Doan on December 26, 2013 at 18:38:28:
Sounds like the throw out bearing is installed incorrectly. Is it possible to have the bearing assembly slip behind the fork,if the pedal was down when the throw out bearing carrier was installed? The bearing carrier has two return springs on it. I think, you should feel a little resistance from those springs.
Posting not permitted in the forum archives.<1388104255">
