Re: Touch Control
Posted by Bruce (VA) on November 21, 2013 at 13:31:52 [URL] [DELETE] :
In Reply to: Touch Control posted by Tim Couch on November 21, 2013 at 12:13:31:
" Is it out of adjustment?"
If you plan on keeping the tractor & want it to work correctly, pull the top cover, rebuild the lift cylinder & adjust the linkage. Then, drop the pump for a good cleaning. Otherwise, many folks have lived w/ the symptoms you described for years.
See tips 3 & 4 re the fluid change.
Post back if that's what you want to do & you will get plenty of advice.
Posting not permitted in the forum archives.<1385055112">
