A while back I posted about my lift arms being stuck up. Last night I put a newly purchased blade on them and then went down.
Now the lift moves up and down real smooth and does not leak. I had the blade up in the air for about an hour and it didn't move. When I checked on it this morning it was down.
My question is. When I want to raise or lower the implement I move the touch control lever up and down. Lets say the lever is mostly down, the implement is down, so I raise the lever about an inch and the black goes all the way up. If I move the lever very slowly I can put the blade in the spot I want it but its moving it in increments of 1/8 inch at a time.
I'm assuming that when the lever is at the bottom the implement should be at bottom and when the lever is at top the implement should be at the top and everything in between.
Is it out of adjustment? I just got this tractor running so I don't know how a working unit is supposed to work.
Also, the trans fluid needs changed.
Thank you all for your help,
Tim
Posting not permitted in the forum archives.<1385050411">
