I am trying to find out how to test if a governor is good ar out of adjustment?
My issue is this.
I just bought the tractor less than a month ago and do not know a lot about these but want to try and diagnose if I can. Here we go!
First when you pull down the throttle I do not get an increase in rpms until the throttle is pulled all the way down.
Second it does not not seem to keep the rpms when I am going up a hill with or without a load.
Third I did test to see if when you pull on rod linkage between the carb and governor the governor does pull back.
Any help would be greatly appreciated.
Thanks
Posting not permitted in the forum archives.<1369319573">
