In Reply to: Re: no spark posted by Jack on February 22, 2015 at 09:07:39:
it has been running fine for about two months then the other day when I went to kill it I did my normal shut down on it meaning turn off fuel and let the carb run out of fuel to prevent flooding on the next start up push in switch then cut key off two days later when I went to start it i put key in turned on the fuel to let the carb fill up pull the switch turn the key on and pushed the starter button that's when I found out it would not run so I pulled the plug and checked for fire and there was none
Posting not permitted in the forum archives.<1424622627">
