In Reply to: Re: no spark posted by Bruce (VA) on February 22, 2015 at 12:30:26:
the person who got it running had a wire going to the battery that drained the battery over night so I put a push pull switch on it so I could stop the battery drain then I found out that if I cut the switch off while it was running it would not charge the battery but im not sure if the wire is hooked to more than one item
Posting not permitted in the forum archives.<1424629755">
