In Reply to: Re: no spark posted by 2n on February 22, 2015 at 13:29:15:
" the person who got it running had a wire going to the battery that drained the battery over night so I put a push pull switch on it so I could stop the battery drain "
Wouldn't it have been easier to just fix it correctly?
Google "wiring diagrams JMOR"
Find the wiring diagram for your tractor & follow it.
The problem is just as you described it: " im not sure if the wire is hooked to more than one item "
Neither are we. You can easily kill that EI by reversing polarity or leaving the key on.
So, my advice is to disconnect the battery & then very carefully follow JMOR's wiring diagram. Post back if you have any questions.
Once it is wired so that all of us understand it, finding the spark problem will be easy.
Posting not permitted in the forum archives.<1424630579">
