Re: Ford 951 Special brush cutter
Posted by soundguy on October 10, 2011 at 08:58:25 [URL] [DELETE] :
In Reply to: Ford 951 Special brush cutter posted by Rich on October 09, 2011 at 21:10:42:
i owned a 48" 951 for about 4 ys.. great mower... gave it to a buddy with a small ford to mow with.
I have a manual if you need some pages copied.
here is a parts listing for a 5' model:
1 1 BMB1229 SHIELD Shield, Main, 60" Only, Years: 10/01/1984-09/30/1985
1 1 BMB4628 SHIELD Shield, Main, 60" Only, Years: 10/01/1985-09/30/1987
1 1 BMB6240 SHIELD Shield, Main, 72" Only
2 1 BMB0711050100 GEARBOX Gearbox, Refer to Fig. 23 for Details
3 4 PL PROCURE LOCALLY Washer, Lock, 9/16"
4 4 PL PROCURE LOCALLY Nut, 9/16"-12
5 1 AUB150023 BRACKET Bracket, Shield
6 1 AUB150166 SHIELD Shield
7 1 PL PROCURE LOCALLY Washer, Flat, 1/2"
8 13 PL PROCURE LOCALLY Nut, 1/2"
9 2 AUB150004 SUPPORT Brace, Rear
10 8 PL PROCURE LOCALLY Bolt, HH, 1/2"-13 x 1-1/2"
11 6 PL PROCURE LOCALLY Nut, 5/8"-11
12 12 PL PROCURE LOCALLY Washer, Lock, 1/2"
13 1 AUB150013 SPACER Spacer, Rear Brace
14 1 AUB150011 LINK Link, Top
15 2 AUB150005 FRAME A-Frame
16 1 PL PROCURE LOCALLY Bolt, 5/8"-11 x 5-1/2"
17 4 PL PROCURE LOCALLY Washer, Lock, 5/8"
18 2 BMB4366 SUPPORT Brace, Angle
19 1 BMB4361 SUPPORT Brace, Inside R.H.
20 1 BMB4362 SUPPORT Brace, Inside L.H.
21 2 BMB4367 Mounts, A-Frame
22 2 AUB150021 PIN Pin, Hitch, Category 1
23 1 BMB4572 DRIVE SHAFT Driveline, 60" Only, Refer to Fig. 24 for Details, Years: 10/01/1984-09/30/1985
23 1 BMB4572 DRIVE SHAFT Driveline, 60" Only, Refer to Fig. 25 for Details, Years: 10/01/1985-09/30/1986
23 1 BMB4662 DRIVE SHAFT Driveline, 60" Only, Used W/Slip Clutch, Refer to Fig. 26 for Details, Years: 10/01/1986-09/30/1987
23 1 BMB1078 Driveline, 72" Only, Refer to Fig. 24 for Details, Years: 10/01/1984-09/30/1985
23 1 BMB4576 DRIVE SHAFT Driveline, 72" Only, Refer to Fig. 25 for Details, Years: 10/01/1985-09/30/1986
23 1 BMB4660 Driveline, 72" Only, Used W/Slip Clutch, Refer to Fig. 26 for Details, Years: 10/01/1986-09/30/1987
24 1 AUB963061 SHEAR BOLT Bolt, Only Shear, 60", 1/2" x 3-1/2", G2
24 1 AUB150115 PIN Pin, 72" Only, Shear
24 1 PL PROCURE LOCALLY Pin, Cotter, 1/8" x 1", 72" Only
25 1 AUB150050 SNAP RING Ring, Snap
26 1 BMB1219 FRAME Frame, Gauge Wheel
27 2 BMB3140 SEALING RING COLLAR Collar, Set
28 1 BMB8713 FORK Fork, 60" Only, Gauge Wheel, Years: 10/01/1984-09/30/1986
28 1 BMB8713 FORK Fork, 72" Only, Gauge Wheel, Years: 10/01/1984-09/30/1986
28 1 BMB8713 FORK Fork, 60" & 72", Gauge Wheel, Years: 10/01/1986-09/30/1987
29 1 88945 BOLT Bolt, Hex, G5, 3/4"-10 x 8", Axle
30 1 AUB964033 NUT Nut, Lock, 3/4"
31 2 PL PROCURE LOCALLY Bolt, 5/8"-11 x 2"
32 1 AUB150057 WHEEL ASSY Wheel Assy., W/Tire & Hub, Includes: Ref. 32A-39
32A 1 AUB150057 WHEEL ASSY Tire
33 2 AUB150079 DRIVE BUSHING Bearing
34 2 BMB1429 Wheel, Half, No Longer Serviced
35 1 BMB4374 HUB Hub
36 4 PL PROCURE LOCALLY Bolt, HH, 1/2"-13 x 1-1/4"
37 4 PL PROCURE LOCALLY Bolt, HH, 3/8"-16 x 3/4"
38 4 PL PROCURE LOCALLY Washer, Lock, 3/8"
39 4 PL PROCURE LOCALLY Nut, 3/8"-16
40 2 AUB150052 WASHER Washer, 3/4"-18 Ga.
41 2 PL PROCURE LOCALLY Washer, Lock, 5/16"
42 2 PL PROCURE LOCALLY Nut, 5/16"-18
43 1 BMB8210 Bar, Rotor, 60" Only, FLAT BAR, No Longer Serviced, Years: 10/01/1984-09/30/1985
43 1 BMB8221 BAR Bar, Rotor, 72" Only, OFFSET BAR, Years: 10/01/1984-09/30/1985
43 1 BMB8221 BAR Bar, Rotor, 60" & 72", OFFSET BAR, Years: 10/01/1985-09/30/1987
44 1 AUB150393 KIT Knives, 60", Only Sold in Pairs
44 1 AUB150394 TILLAGE BLADE Knives, 72", Only Sold in Pairs
45 2 AUB150020 BOLT Bolt, Knife, Years: 10/01/1984-09/30/1985
45 2 AUB150069 KIT Kit, Bolt, Knife, Includes: Ref. 46, Years: 10/01/1985-09/30/1987
46 2 AUB964035 NUT Nut, W/Nylon Insert
47 2 AUB231239 WASHER Washer
48 2 AUB150042 WASHER Washer
49 2 AUB150041 NUT Nut, Slotted, 1"-14
50 1 PL PROCURE LOCALLY Pin, Cotter
51 1 BMB8223 Dishpan Assy., 60" Only, Years: 10/01/1984-09/30/1985
51 1 BMB8225 Dishpan Assy., 72" Only, O.D. 29", Years: 10/01/1984-09/30/1985
51 1 AUB150407 Dishpan Assy., 60" & 72", O.D. 28", Years: 10/01/1985-09/30/1987
52 1 PL PROCURE LOCALLY Key, Cotter, 3/16" x 2-1/2"
53 1 AUB150012 PLATE Plate, Cover
54 1 PL PROCURE LOCALLY Bolt, HH, 5/8"-11 x 2"
55 1 BMB6257 PIN Pin, Upper Hitch, Years: 10/01/1985-09/30/1987
56 1 PL PROCURE LOCALLY Pin, Cotter, Years: 10/01/1985-09/30/1987
57 2 PL PROCURE LOCALLY Nut, Lock, 7/8"-14, Years: 10/01/1985-09/30/1987
58 1 AUB150646 WHEEL ASSY Wheel Assy., Complete W/Tire & Segments, Models 22BM1473 & 1474, Includes: Ref. 59-67, Years: 10/01/1985-09/30/1987
59 1 NSS NOT SERVICED SEPARATELY Wheel Assy., Complete L/Tire & Segments, Includes: Ref. 60-62
60 1 AUB150644 Rim, Wheel, L/Hub
61 2 AUB150056 BUSHING Bearing, 3/4" I.D. x 1-3/8" O.D.
62 1 AUB150644 Wheel, W/Hub
63 1 220248 TYRE/TIRE Tire, Laminated
64 4 NLS No Longer Serviced Segments
65 8 PL PROCURE LOCALLY Bolt, HH, 3/8"-16 x 3/4"
66 8 PL PROCURE LOCALLY Washer, Lock, 3/8"
67 8 PL PROCURE LOCALLY Nut, Hex, 3/8"-16
73 2 BMB8287 Spacer, 72" Only, No Longer Serviced, Years: 10/01/1986-09/30/1987
74 1 BMB8735 CLUTCH Clutch, Slip, Refer to Fig. 27 for Details, Years: 10/01/1986-09/30/1987
75 1 PL PROCURE LOCALLY Bolt, HH, G8, 1/2"-13 x 3", Years: 10/01/1986-09/30/1987
76 1 PL PROCURE LOCALLY Nut, Hex, 1/2"-13, Years: 10/01/1986-09/30/1987
77 1 AUB150050 SNAP RING Ring, Snap, Years: 10/01/1986-09/30/1987
78 1 BMB8676 YOKE Yoke, Flange, 60" Only, Years: 10/01/1986-09/30/1987
78 1 BMB8413 YOKE Yoke, Flange, 72" Only, Years: 10/01/1986-09/30/1987
79 6 BMB8372 CAP COVER Screw, Cap, 8mm x 18mm, Years: 10/01/1986-09/30/1987
Posting not permitted in the forum archives.<1318251505">
