Re: 6 V Single Wire Generator Rebuild --Pics
Posted by JMOR on July 24, 2011 at 03:46:25 [URL] [DELETE] :
In Reply to: 6 V Single Wire Generator Rebuild --Pics posted by Muchbroker on July 23, 2011 at 22:54:46:
Tensioning bracket bolts to the barrel, which is idenity key, meaning that you have a 2N10000 generator. The 9N10000C would have been very similar, but would not have had the barrel tapped for the tensioning bracket. If by "type", you meant as in 9N10000A, 9N10000B, 9N10000C, then the answer is no, as the 2N10000 used no suffix letters. If by type, you meant "B-circuit", then the answer is no, as by definition, the "B-circuit" has an externally supplied Field & would thus not have a 3rd brush & by necessity would have a Field terminal. The pulley screws onto threaded armature shaft. Bushing, bearing & brushes are available from Just8Ns as well as others. HTH
Posting not permitted in the forum archives.<1311497185">
