Re: Tight Engine,,,Rebuild
Posted by soundguy on August 12, 2010 at 09:58:36 [URL] [DELETE] :
In Reply to: Tight Engine,,,Rebuild posted by Charles (N.C.) on August 12, 2010 at 09:07:29:
assuming you got the correct bearing shells for your main / rod, and you have all new pistons and rings and liners.. I'd expect her to be tight, but turnable. Use a good assembly lube and if you want an idea of how tight it is.. slip a torque wrench on and see what it is doing.
it's not uncommon to have to pull start a real tight engine on it's first run if the starter won't kick it over.
keep us posted.
soundguy
Posting not permitted in the forum archives.<1281621516">
