In Reply to: 8N 1949 Draw bar question posted by Dave Davis on November 18, 2009 at 12:03:41:
be carefull trying to snatch stumps and roots with your tractor.. you will likely end up with a busted casting.. or a rolled tractor.
ditto what jmor is shoulw you on the drawbar.
also.. you can get a 3pt drawbar lock for 15$ that will keep yer 11 hole drawbar from spinning. that and a set of stays and you are set for pulling a small trailer.
soundguy
Posting not permitted in the forum archives.<1258565509">
