Re: 641 high idle
Posted by WayneIA on October 30, 2014 at 09:16:22 [URL] [DELETE] :
In Reply to: 641 high idle posted by Spud on October 29, 2014 at 20:33:53:
Sounds like you need the remove the carburetor and adjust the throttle. Back the idle adjusting screw all the way to the end then loosen the two screws holding the throttle plate Hold the throttle shaft in the closed position and now tighten the two throttle plate screws
Posting not permitted in the forum archives.<1414674982">
