9n flooded?
Posted by justinB on August 25, 2014 at 21:56:56 [URL] [DELETE] :
My ford 9n was idling pretty high so I adjusted the idle speed screw on the carb until it purred. Then I started adjusting the idle mixture screw inward. I turned it all the way in and the tractor died. I guess I flooded it. Now it won't start. I took out the plugs and cleaned them but still won't crank. Can someone recommend a solution?
Posting not permitted in the forum archives.<1409018216">
