Hello tractor people I need some help. I have recently purchased a 41 Ford 1/2 ton pickup with the original four cylinder motor. The block had a replacement sleeve installed in the number one cylinder but was the wrong size causing the block to shrink and crack horizontally in many places. Didn't find this out till full disassembly of the motor and the person had painted over. So my question is is there anyone out there with a 9N engine block in working condition for sale? The 41 pickup shares the same block but has a hole cut out for side mounted mechanical fuel pump. Everything else about this motor is in great shape just having the crank turned but waiting until I find a usable block. Everything that bolts to this motor is painted and ready to reassemble any help at all will be spectacular. Thanks guys, Tom
Posting not permitted in the forum archives.<1408296606">
