Re: adjusting wheels for cultivating on Ford 9n tractor
Posted by Rockbiter on June 11, 2014 at 09:48:11 [URL] [DELETE] :
In Reply to: adjusting wheels for cultivating on Ford 9n tractor posted by suebdo on June 10, 2014 at 16:36:09:
The rim to center mounting bolts are a BIG factor in being able to get the different combinations as shown in the diagrams the Ed provided.. If they haven't been removed for a long time, you may find it difficult to get them out if you have the original hat rims since they set in with rust so bad. I had to loosen the nut on each one until it was flush with the end of the threads and then using a big hammer and lots of WD-40, drove them through until the nut once again hit the rim center. Then removed the nut and drove them out with a pin punch. Multiply that effort about a dozen times and you can get a good idea of the effort it takes. To go through that process every couple years to get a different width on the rear wouldn't be good. After I drove the old bots out, I could see that the rusting had really taken a toll on the old bolts and throwing them away and getting new bolts was a good idea. I now have the 6-hoop style replacement rims. Much easier to switch around. The only reason I would want the original hat rims is if I was restoring and using the tractor for show rather than use. There will be arguments to the opposite on using the hat rims, I'm sure.
Posting not permitted in the forum archives.<1402494491">
