Tractor Ford 3600 - Rear axle fluid level
Posted by Sylvain Parenteau on May 25, 2014 at 09:56:21 [URL] [DELETE] :
I found instructions on how to check the fluid after I filled it up. Then, following the instructions on how to check the fluid level in the rear axle I found out that I have too much fluid - the fluid leaks from the full size plug hole... the tractor is leveled with all lifts up (three-point & front loader) to maximum position.
Qt: Will this damage the hydraulic system or the rear axle if I run it with too much oil/fluid?
I filled this up with 5 gallons two weeks ago from the rear big plug because the loader didn't work (very slow); now the loader operate fine. I couldn't see the fluid at all accumulating in the rear axle when filling. The rear tri-point was low, the loader mid- position...
Thanks,
Sylvain
Posting not permitted in the forum archives.<1401029781">
