Re: New distributor
Posted by Bruce (VA) on February 28, 2014 at 18:18:11 [URL] [DELETE] :
In Reply to: Re: New distributor posted by Ultradog MN on February 28, 2014 at 17:37:23:
" EI doesn't care if your bushings are worn or if your cam lobes are worn"
That's not true & you know it's not true.
Slight wear is ok, but EI has specs just like points. They just have greater tolerances.
Posting not permitted in the forum archives.<1393629491">
