Re: Ford 600
Posted by Mike-ga on February 17, 2014 at 18:51:16 [URL] [DELETE] :
In Reply to: Re: Ford 600 posted by Rockbiter on February 17, 2014 at 11:19:30:
Yeah,mine is like the one in the manual. I primed the pump and it pushes oil out the front pipe fitting hole, and under the seat at that top pipe fitting hole (on top of adapter plate) IF the position control is not at the top of it's travel???? If the position control is lower on the quadrant, a great deal of oil is pushed out, not really "spraying" out. I have to get me an allen socket to access the test port on the right side of the tractor under the foot board.If I have oil flow there I guess I have a stuck valve, as the lift arms still do not work. The lift arms worked the other day when I took it off the trailer after I bought it, if the quadrant was all the way up and it was in position control. That was after it sat and ran for several minutes, now 2weeks later they do not lift at all.
Posting not permitted in the forum archives.<1392681076">
