In Reply to: Re: Ford 600 posted by Kurt-NEPA on February 18, 2014 at 07:55:14:
When takingoff the pressure side plug on the pump,it sprayed out onto me and the tractor ( I believe this happened only because there was some restriction while the plug was still somewhat in the pump, with the plug removed the oil was pumped out but did not spray). When I take the plug out under the seat on the adapter plate, the oil will only come out if the position control lever is NOT in the fully raised position. When the oil does come out, it comes out but does not spray out. The lift did work and seemed stout if the position control was in the fully raised position before, now the lift arms do not move.
Posting not permitted in the forum archives.<1392783304">
