Re: Generator Testing
Posted by Bruce (VA) on November 29, 2013 at 10:01:33 [URL] [DELETE] :
In Reply to: Re: Generator Testing posted by Tim Couch on November 29, 2013 at 09:43:22:
6v or 12v?
" Can the generator charge more than the 8 volts or so that's needed?"
Yes.
That's why there is a voltage regulator in the circuit.
Use the flow chart to trouble shoot the problem.
Or, just replace all the wiring, v/r etc and assume it will fix the problem.
BTW......if you remove the breather & tool box, rewiring & installing a new v/r is much easier.
Posting not permitted in the forum archives.<1385733693">
