Re: Generator Testing
Posted by Tim Couch on November 29, 2013 at 09:43:22 [URL] [DELETE] :
In Reply to: Re: Generator Testing posted by Bruce (VA) on November 27, 2013 at 18:39:01:
Bruce,
Let me give you some background on the tractor. I know very little about its past besides it was my great uncles. The wiring is original with a few splices in it, so it is pretty much shot. I have been putting a charger on the battery assuming its wasn't charging, but after using it for a little while the other day the charger said it didn't need a charge. That got me thinking that it does charge and what if its charging too much? I put my DMM on it but it was bouncing all over, 12 then 18 then somewhere else, this was from the battery terminals.
The ammeter doesn't move ever, so I figured that it is bad or the charging circuit doesn't work. I have a new wiring harness, ammeter and voltage regulator for it, but I haven't had the time to install it.
Can the generator charge more than the 8 volts or so that's needed?
Thank you,
Tim
Posting not permitted in the forum archives.<1385732602">
