Re: 53 ford naa hydraulic loosing prime and pulsing full lift
Posted by peter on July 02, 2013 at 00:38:36 [URL] [DELETE] :
In Reply to: 53 ford naa hydraulic loosing prime and pulsing full lift posted by peter on July 01, 2013 at 15:49:43:
i checked tonight with a camera through the inspection cover on the right side and i see a very very slow drip from the piston, and also a constant stream of oil from the top right side. (should be kind of in front of the draft control lever on the top right under the accessory plate) should that constant flow be there?? picture of the area attached
Posting not permitted in the forum archives.<1372739916">
