In Reply to: 9N runs bad posted by Mark on April 28, 2013 at 12:17:30:
The carb is pretty simple as far as carbs go. Pick up a kit for it, and check out the how-to forum for info on detail cleaning and adjustment. A little sour gas and fine sediment can sure make her run rough. Turns out the various screens are not quite fine enough to get all the dirt, and some stuff gets into the carb. There is a tube inside, can't recall its proper name, but this tube has a couple of very small holes in its side which become stopped. A single bristle from a wire brush is about right for cleaning these out. If the tractor sat parked for a longish time, you may have to clean the carb more than once as the sediment works its way out of the system.
Also check that the little fiber ring is present under the spring on the large adjustment screw.
Posting not permitted in the forum archives.<1367167759">
