Re: 9N runs bad
Posted by Mike Wilson, Catlett's Station on April 28, 2013 at 22:02:34 [URL] [DELETE] :
In Reply to: Re: 9N runs bad posted by Mark on April 28, 2013 at 17:08:39:
I don't know if carb spray will do the job or not.
My second N had remained unused for a time, and when I began using it, the sloshing of the fuel in the tank stirred up quite a bit of very fine rust particles. A considerable amount filtered through the screens and settled in the bottom of the carb, and also clogged the tiny hole, or holes, I can't remember, in that small tube. I didn't use any gasket shellac on the carb gaskets and opened and cleaned that carb several times before the tank ran out of sediment. Even did the job in the field using a hay wagon for a work bench. After you've done the job once or twice, you could do it in your sleep.
Might help to drain the carb via that bolt/plug in the bottom, and then hose it down with carb cleaner through that opening.
Posting not permitted in the forum archives.<1367200953">
