Re: Carb poll
Posted by Ed Gooding (VA) on July 06, 2024 at 05:16:26 [URL] [DELETE] :
In Reply to: Carb poll posted by Josh in Texas on July 05, 2024 at 20:11:34:
Only if I find that starting/running issues are fuel related and the three filters are clean, gas tank vent is open, etc. A simple diagnostic that you can perform is to open the valve on the sediment bowl, get a pint Mason jar and remove the drain bolt from the fuel bowl on the carb. If it quickly (maybe a minute or so) fills the Mason jar you know you are getting good flow through it.
If you want to do it "just because", we have some good info in our How-To's library here to be a guide for you.
