In Reply to: points gap/oil pump posted by Bri on August 24, 2012 at 10:17:28:
" eccentric"?
Geez, you must be older than me! (63) :)
Just because I’ve never experienced a worn out distributor cam doesn’t mean it can’t happen.
Specs for the frontmount are:
Across flats = .789/.791
Over lobes = .869/.871 dia.
It's going to run much better w/ a .015 gap & the timing set correctly.
Have you set the timing according to the I&T FO4 manual?
You can retard or advance the timing a bit to account for some of the closer gap.
Posting not permitted in the forum archives.<1345849807">
