Re: '52 8N stalls and won't re-start / follow-up
Posted by Stu Gary on June 23, 2010 at 11:12:30 [URL] [DELETE] :
In Reply to: Re: '52 8N stalls and won't re-start posted by Stu Gary on June 22, 2010 at 09:48:27:
As promised, here's an FYI for all, I followed the Pertronix Low Voltage test that you sent me to the letter.. Thank you again for doing that, I really appreciate it.
The Test results showed that the Coil was fine and in good working condition..
However, the Ignitor Module Test failed... According to test protocol, voltage was to fluctuate between battery voltage, tested at 12.8 volts, and 0 while rotating..
I measured a constant voltage reading of 11.4 volts.. This according to the test protocol #6) A constant measurement indicates that the power transistor or hall cell may have failed.
Posting not permitted in the forum archives.<1277305950">
