In Reply to: Re: '52 8N stalls and won't re-start posted by JMOR on June 21, 2010 at 16:28:28:
That is a good idea and thanks for the Low Voltage test.. Fussin' with this attempting to find a spark when she's hot sounds difficult to accomplish..
Testing the coil with a volt meter sounds useful, since I have to pull the module to check for burn marks, per instructions on the low voltage test, I might as well re-install the points system and see where we are at..
It seems it's been narrowed down to the ignition system somewhere, that is failing when it heats up after a 15 to 20 minute run.. Again, it's been running smooth since the original install last August of '09..
Thanks for all of your input, direction & help and will let you know what I find, when I find it..
Posting not permitted in the forum archives.<1277214507">
