In Reply to: Using Car Wheels on a 9N or 2N posted by Jim.UT on May 29, 2009 at 20:23:44:
Hey Jim - That's a good info. I had asked you too see the rims when you had them in the ads section because I had the same thing on my 2N. They were the same Ford car rims, and the hubs were from a Ford car or truck. The hubs had a different offset than the hub in your pic, my hubs actually set the rim in closer to the axle just allowing a 6x16 tire not to rub just barely. I ended up buying original 2N hubs and 19" rims because this was about the only thing that had been changed on my 2N... everything else was original to the tractor. Keith
Posting not permitted in the forum archives.<1243648958">
