Six or seven weeks ago I asked for thoughts on adding a control valve to a 641, UD and TOH both responded and I now have a Ford single spool valve. Now my problem, valve is in great shape and I added new O rings but have a constant leak at front right corner. I've removed the control three times, inspected the surfaces installed new O rings and reinstalled but still the leak. Could it be maybe thicker O rings in the two openings just behind the bolt on that side ? Am I missing something obvious? I also added a set screw to seal the 5/16" bolt hole in the center from the block off plate.
Any ideas to get the 641 usable would be appreciated
Thanks
Tom from Mi.
Posting not permitted in the forum archives.<1504730068">
