In Reply to: Re: 641 Hydraulics question posted by ZANE on July 04, 2017 at 20:24:57:
I found this file that I had written years ago before I started to become senile. It may explain this procedure better.
REMOTE VALVE MODIFICATION TO HUNDRED SERIES LIFT
Remove the remote valve adapter plate from the top of the lift cover. There will be a hole under the plate that will gush oil when the engine is turned with the starter. Drill and tap this hole to receive a 1/4 inch Allen hex pipe plug. Directly above this plug drill and tap a hole through the adapter plate to receive a 1/4" pipe street ell fitting.
Remove the plug from the test port at the lower right side of the differential/hydraulics and route a hose from the test port to the control valve/s “in” port you wish to use to operate remote cylinder/s. Then route a hose from the control valve/s “out” port to the street ell you have set into the adapter plate. As long as the remote valve is not being used the three point hitch will work as usual. The three point will not work when using the remote valve/s
Zane
Posting not permitted in the forum archives.<1499214543">
