In Reply to: Belly mount grader blade? posted by Farmer Dan on December 16, 2012 at 17:18:50:
Farmer D.,
For what it is worth, I have found that a back grader blade with a tilt and angle works best for grading a road. You get a little crown and can make a ditch. A front end loader really helps for clearing the brush. You might be able to do the same thing with your snow blade... Another reason I got the kubota with 4wd loader etc. I can push over 8" trees and pull out the roots...HTH... S.
Posting not permitted in the forum archives.<1355704510">
