Re: Ford 8n ball hitch
Posted by Ken-Pa on April 28, 2012 at 00:10:34 [URL] [DELETE] :
In Reply to: Ford 8n ball hitch posted by Sheldon Stackelhouse on April 27, 2012 at 23:41:54:
If using a 11 hole drawbar , you must buy or fabricate a drawbar stay such as the V set-up or the lock set-up which holds the drawbar tight to the lft arm . I believe you will find help with these in the mauals or How tos sections across the to of page . You will also need to use a set of atabilizer bars to keep the drawbar at the desired heighth . This issue has been discussed many times before . HTH ! God bless, Ken
Posting not permitted in the forum archives.<1335586234">
