In Reply to: Re: hydraulics posted by StanNMi on August 12, 2010 at 15:56:07:
Good morning, well last night I rigged up my block and tackle, which is normaly used for hanging whitetails and the odd beef, and removed the lift cover. I made sure to disconnect the control rod and the unit is sitting on my bench all cleaned up waiting for ew parts. I used a long knife edge to check for grooves inside the ram cylinder and it checked out ok.This evening I'll remove the pump, and I'm undecided whether or not to soak it as whole or break it down and clean it out. Our NAPA store carries a product #14540 TDH Universal Tractor Fluid, it sells for $50. The only prblem is they cant seem to give me a spec on it. New Hollands runs about $68 for 5 gal. Is anyone familiar with the NAPA product? I order the I&T FO4 manual from NH for $46 and it'll be here with my other parts on Monday, the advice on this board anytime PRICELESS!!! Thanks again. Mike
Posting not permitted in the forum archives.<1281711319">
