Re: need info about camshaft gear
Posted by 36 coupe on October 12, 2014 at 06:41:27 [URL] [DELETE] :
In Reply to: need info about camshaft gear posted by Serge on October 11, 2014 at 19:32:16:
Its a press on gear.Cam shaft has to come out.You can see wear on the teeth if its bad enough.Ford cars and trucks used the same gear.I wouldnt mess with a used gear.Early V8 engines used a finer toothed gear so the tooth count is important.The gear is marked on the hub and has a timing mark on the rim.
Posting not permitted in the forum archives.<1413110487">
