Hello All,
I started a while back working on my hydraulic issues then had a few things come up. I left off with the top cover off, and found out it was cracked. I found one locally and purchased it.
Now i'm at the point of making sure top cover is adjusted properly. I have Zane's jig, although i'm having trouble figuring out how to use it. It came with directions, but the pictures are blurry. Do you know if someone has made a video on how to use it?
Also, the hydraulic lift lever seems loose. It doesn't fall when you let it go but it doesn't have a lot of resistance. Is that the Hydraulic Lift Control Plate or the friction disc?
How do you get the plate off to replace the disc?
As always, thank you.
Tim
Posting not permitted in the forum archives.<1410988583">
