In Reply to: Re: Hydraulic troubles posted by HCooke on July 30, 2014 at 08:25:25:
i'm just a dumb old redneck..but the cam follower pin is something i would have checked before i put the donor assembly over on the tractor. you will have to pull it back off to check. but you will have to pull it back off to check the adjustments anyway. you might have been in better shape to have put a new piston in your old unit.
Posting not permitted in the forum archives.<1406769651">
