Re: 8N Backfires through the exhaust
Posted by Rockbiter on May 19, 2014 at 17:34:03 [URL] [DELETE] :
In Reply to: 8N Backfires through the exhaust posted by Jon Bennett on May 19, 2014 at 17:14:54:
I would see if I could isolate it to a particular cylinder. Pull one plug wire at a time and see if there is a noticeable difference in how it sounds and runs. Might be a valve issue.
A couple other things I know can cause backfiring is moisture in the ignition, water in gas, plug wire on incorrectly.
HTHs
Posting not permitted in the forum archives.<1400538843">
