Re: Carb. Spring
Posted by Texas! on May 05, 2014 at 07:32:37 [URL] [DELETE] :
In Reply to: Carb. Spring posted by Jack - Iowa on May 05, 2014 at 07:15:38:
That spring holds the little flapper valve on the choke plate. Look in the air intake of the carb and you will see the choke plate mounted on the choke shaft that passes through the carb. There will be a large hole in the choke plate and the flapper valve covers that hole. The spring should be available separately.
Posting not permitted in the forum archives.<1399293157">
