Re: summary so far, Jub choke problem
Posted by JMOR on April 28, 2014 at 12:49:38 [URL] [DELETE] :
In Reply to: Re: summary so far, Jub choke problem posted by Walt/Tx on April 28, 2014 at 12:40:56:
Walt, in addition to that paper's collection, here is one more that shows in purple/violet, the simple path for fuel in the power at speed operation. Not much there. Look very closely at the seat at bottom of power adjust needle. I found one where someone had rammed some hard object in through the exterior plug hole at bottom of nozzle & partially sheared that brass seat & nearly stopping fuel flow, no matter where the power adjust needle was set. Don't be offended at this question, as I know you have worked on many, but 'stuff' can happen......are you certain that the venturi isn't in upside down? Yes, it can be assembled that way.
Posting not permitted in the forum archives.<1398707378">
