In Reply to: Re: Antifreeze leak. posted by don b on March 12, 2014 at 11:36:59:
On on one of my rebuilds the new replacement water pump had a high casting ridge on the hose connection spout that prevented the hose from sealing properly. The only way I got it to stop leaking was to take off the hose and grind that casting ridge flat. Since then I have found that same high casting ridge on two other new water pumps.
Posting not permitted in the forum archives.<1394808954">
